I would like to retrieve the logs from the "Installation Logs for package ***" to more easily audit my infrastructure. The goal is to create a CSV file named "Machine;Installation Logs for package ***".
I have tried to perform this operation via a query in the reporting system as well as through the API, but I haven't found a solution.
I am currently using Enterprise version 2.2.0.11720.
[RESOLVED] Package installation logs
I can offer you this:
Would that suit you?
Yours sincerely
SELECT
h.computer_name AS Machine,
h.computer_fqdn AS FQDN,
p.name AS Package_Name,
p.install_status AS Installation_Status,
p.install_date AS Installation_Date,
p.install_output AS Installation_Logs
FROM
hostpackagesstatus p
JOIN
hosts h
ON
p.host_id = h.uuid
WHERE
p.install_status IS NOT NULL
ORDER BY
h.computer_name, p.install_date;Yours sincerely
Hello Jarnaud,
Great, that's perfect!
Is it possible to retrieve this request via the API? (I haven't seen this feature).
Something like this: https://wapt.myserveur.local/api/v3/reporting?id=3
- Attachments
- api.png (8.46 KB) Viewed 7909 times
Hello Emeric,
Of course, it's possible.
https://www.wapt.fr/fr/doc/wapt-api.htm ... rting-exec
I'll let you customize the username and password of a WAPT server user.
And you need to replace 2 with your SQL query number (you can see the SQL query IDs in the reporting tab in the left panel), for example:
Best regards
import os
import json
import logging
import waptlicences
import requests
import sys
sys.path.append('/opt/wapt')
from common import get_requests_client_cert_session
from common import Wapt
WAPT = Wapt()
ini_wapt_path = WAPT.config_filename
w = Wapt(config_filename=ini_wapt_path)
# WAPT Conf
wapt_url = w.waptserver.server_url
user = "reporting"
password = "password"
def run_report():
t = waptlicences.waptserver_login(ini_wapt_path,user,password)
session = get_requests_client_cert_session(wapt_url,
cert=(t['client_certificate'],t['client_private_key'],t['client_private_key_password']),
verify=w.waptserver.verify_cert
session.cookies.set(t['session_cookies'][0]['Name'], t['session_cookies'][0]['Value'], domain=t['session_cookies'][0]['Domain'])
t= None
url = f'{wapt_url}/api/v3/reporting_exec?id=19'
response = session.get(url)
data = response.json()
return data['result']
print(run_report())I'll let you customize the username and password of a WAPT server user.
url = f'{wapt_url}/api/v3/reporting_exec?id=2- dcardon
- WAPT Expert
Hello Emeric,
regarding your WAPT version, version 2.2 is no longer supported and it would be best to upgrade to 2.5 or even 2.6.
Regards,
Regards,
