I've searched the forum but haven't found anything, so I'm posting my question here.
Is it possible (and if so, how) to create a package to inject Wi-Fi parameters (SSID + password)?
I found a solution using Group Policy, but using WAPT would allow me to refine the settings on which to deploy the different SSIDs.
Thank you in advance for your reply.
[SOLVED] Wifi configuration package (SSID and MDP)
Emmanuel64
- Registration: February 23, 2024 - 09:37
WAPT Enterprise
Version 2.6.1.17576
Version 2.6.1.17576
it's quite simple, you need to use the netsh command.
The page https://www.it-connect.fr/import-et-exp ... vec-netsh/ will give you the command lines to use.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
Emmanuel64
Good morning
Sorry, I didn't see the reply... Thank you
How do you then integrate the powershell command into a package?
I put the XML file in the package and then edited the setup.py file:
I think the idea is there, but the syntax, much less so
run_powershell(Invoke-Expression 'netsh wlan add profile filename='monWiFi.xml' user=all')WAPT Enterprise
Version 2.6.1.17576
Version 2.6.1.17576
fschelfaut
- Registration: Nov 7, 2024 - 12:22
The double quotes were missing in the run_powershell function!
I think this snippet of code would be better:
Flavien,
run('netsh wlan add profile filename="monWiFi.xml" user=all')
Emmanuel64
Great!
Thank you so much for your help and your quick response.
WAPT Enterprise
Version 2.6.1.17576
Version 2.6.1.17576
- WAPT Expert
Hi Emmanuel,
thanks for the feedback!
Feel free to spread the word about WAPT; word of mouth is also how WAPT spreads.
- Denis
- Denis
