the 2.6 changelog mentions that Rustdesk can be integrated into the console.
What is the procedure?
I don't see an audit package for Rustdesk as indicated in the changelog.
Thank you!
[SOLVED] WAPT console 2.6 + Rustdesk
- WAPT Expert
the package https://wapt.tranquil.it/store/fr/tis-r ... g-template allows you to retrieve the audit log and also configure the Rust Desk agent.
This package allows you to set a random password for the Rust Desk configuration.
It also allows you to configure the Rust Desk agent.
Run an updatepackage on tis-rustdesk-config-template to install the package.
- WAPT Expert
Do you have RustDesk installed on your own machine?
- WAPT Expert
Since the console needs the RustDesk binary to initiate the connections, yes
