WADS - VerifyCert Error
Answer
Kavinus
December 11, 2024 - 10:58 PM
I am encountering a problem during deployment at the "VerifyCert" step since upgrading to version 2.6.
Thank you for your help.
Windows Server 2022 21H2
WAPT Server version: 2.6.0.16613
WAPT Agent version: 2.6.0.16613
WAPT Setup version: 2.6.0.16613
WAPT Deploy version: 2.6.0.16613
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
December 12, 2024 - 09:48
The `verify cert` command seems to be working correctly.
However, you are not retrieving an IP address from your DHCP server.
You can check your configuration using the documentation: https://www.wapt.fr/fr/doc/wapt-wads.ht ... p-for-wads
Regards,
December 19, 2024 - 2:22 PM
Hi Kevin,
indeed, as the message indicates, WinPE failed to obtain an IP address. Therefore, either there's a DHCP configuration problem, or the network drivers for the specific hardware are missing. These need to be added when creating WinPE.
Regards,
Answer
