[SOLVED] glpi-plugin-export-to-glpi10
TomTom
Registration: May 25, 2018 - 3:43 p.m.
December 13, 2024 - 10:11
Hello everyone,
Since updating our server to version 2.6, the data transfer to GLPI is no longer working correctly.
Oddly, only 36 machines out of our 240 are transferring correctly. The vast majority are servers running Debian/Ubuntu.
Can anyone help me with this?
Thanks in advance
, Thomas
WAPT version: 2.6.0.17392 (Enterprise Edition)
Server OS: Debian 12 "Bookworm"
Administration/package creation machine OS: Windows 11 24h2
blemoigne
Registration: July 17, 2020 - 11:29
December 17, 2024 - 11:24
Hi Thomas,
You can install the audit-glpi-inventory package on all machines to get the official GLPI inventory and then try exporting it again.
Have a good day,
Bertrand
TomTom
December 17, 2024 - 1:57 PM
Hi Bertrand,
Has the way things work changed with version 2.6? I'd like to avoid deploying an agent on my machines.
Letting the server handle it seemed like a good idea, though.
December 17, 2024 - 5:09 PM
On the machines in WAPT that aren't reporting correctly, do you have any information in the audit data tab?
Are you using the latest version of the GLPI audit export package?
TomTom
December 18, 2024 - 08:17
Hello Simon,
Yes, I am indeed using the latest version. However, I do have audit data, but there are errors on some workstations that are not being reported
{"status":"error","message":"JSON does not validate. Violations:\nString expected, 2022 received at #->properties:content->properties:monitors->items[0]:0->properties:description\n","expiration":24}
December 18, 2024 - 1:29 PM
From what I understand, it's not working because this part of the export package code isn't functioning:
        # MONITOR
        for monitor in self.data["host_info"].get("monitors", {}):
            newmonitor = {
                "base64": monitor.get("b64_edid", ""),
                "caption": monitor.get("name", "") if monitor.get("name", "") else "Not Found",
                "description": monitor.get("manufactured", ""),
                "manufacturer": monitor.get("manufacturer", ""),
                "port": monitor.get("port", ""),
                "serial": str(monitor.get("serialno", "")),
            jsondata["content"]["monitors"].append(delete_empty_entry_in_dict(newmonitor))
And from what I understand, it's the value of "manufactured" that's the problem.
in the inventory of equipment:
host_info->monitors->[*]->manufactured
It must be formatted incorrectly...
As Bertrand indicated above
You can install this package on the machine:
https://wapt.tranquil.it/store/fr/tis-a ... -inventory
It allows you to retrieve the GLPI inventory in the machine audit data tab.
This allows sending the exact same inventory from GLPI to GLPI (in this case, the GLPI inventory is not rebuilt from the Wapt inventory; it actually uses the GLPI inventory, so Wapt acts as a gateway)
When the glpi-plugin-export-to-glpi10 package runs, if it sees that an audit record "audit-glpi-inventory" is available, then it directly uses that record
TomTom
December 18, 2024 - 2:34 PM
Thanks Simon for the explanations, I'm starting to understand the workings of this GLPI audit package a bit better.
Indeed, after deploying it, my machines are once again uploading their inventory to GLPI. Great!
Another question: why does the audit-glpi package for Linux have a dependency? Can it be deployed without it?
December 18, 2024 - 3:30 PM
TomTom wrote: ↑Dec 18, 2024 - 2:34 PM Another question: does the audit-glpi package for Linux have a dependency? Can it be depolymerized without it?
Indeed, the tis-audit-glpi-inventory package has a dependency on tis-glpi-agent because it really needs the GLPI agent to build the inventory
The GLPI agent is only used to generate the inventory; it is not connected to a server
TomTom
December 18, 2024 - 4:56 PM
The inventory of Linux machines is now up to date.
Thank you very much, Simon and Bertrand. I'm closing this!
