[SOLVED] MS Edge: It's still not working!
t.heroult
Registration: December 8, 2020 - 10:13 AM
December 20, 2024 - 10:55 AM
Good morning
Since you implemented scheduled task management in the MS Edge package, I have been getting installation errors all the time.
Example with the most recent one (131.0.2903.112-46):
Installing: MicrosoftEdgeEnterpriseX64.msi (131.0.2903.112)
Waiting for key: {D8A6BB3B-CDD1-3B3E-B1CB-89329C55D211} to appear in Windows registry
  File "C:\Program Files (x86)\wapt\common.py", line 4294, in install_wapt
  File "C:\Windows\TEMP\wapt3km0znqs\setup.py", line 86, in install
TypeError: string indices must be integers
With each new package, I am forced to remove the two blocks (before and after installation) that manage this.
I am counting on you to correct this flawed management :)
Tom
Consoles: Windows 10 & 11
Infrastructure: Windows
fschelfaut
Registration: Nov 7, 2024 - 12:22
January 7, 2025 - 3:23 PM
I've modified the Edge package to better handle scheduled tasks.
The package is currently and will be available on the store tomorrow.
Please give us your feedback on the changes,
Flavien.
t.heroult
January 9, 2025 - 12:39
OK, I'll keep an eye on it and I'll keep you posted :)
t.heroult
January 13, 2025 - 11:07
Everything looks OK, I'm closing the ticket.
Thank you!
January 13, 2025 - 11:14
Hi Thomas,
thanks for the feedback :-)
Denis.
PS: Hoping Microsoft doesn't change its operating methods again in the next Edge release... :-)
