[RESOLVED] UPDATE 2.6.0.16767: No more HTTP access!!!
t.heroult
Registration: December 8, 2020 - 10:13 AM
January 10, 2025 - 12:39
Good morning
I just installed the latest version of WAPT and nothing works anymore!
I can no longer connect via the web browser or via the console.
The login information is being rejected even though it is correct...
Server log:
Jan 10 12:33:27 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:27,779 [waptauth       ] WARNING Failed auth for None from MON_IP path /
Jan 10 12:33:29 SRVWAPT-SRV waptserver[1682740]: 2025-01-10 12:33:29,146 [waptauth       ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:05 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:05,588 [waptauth       ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:34:07 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:34:07,284 [waptauth       ] WARNING Failed auth for MON_LOGIN from MON_IP path /
Jan 10 12:35:56 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:35:56,728 [waptauth       ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
Jan 10 12:40:09 SRVWAPT-SRV waptserver[532]: 2025-01-10 12:40:09,073 [waptauth       ] WARNING Failed auth for MON_LOGIN from MON_IP path /api/v3/login
Any ideas?
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
January 10, 2025 - 12:56
is this an LDAP or admin connection?
In the changelog, we specified
[REF] waptserver: remove config wapt_admin_group_dn replace by wapt_admin_group (specify a samaccountname).
Do you have wapt_admin_group_dn in your configuration or wapt_admin_group?
t.heroult
January 10, 2025 - 12:59
LDAP connection.
I just checked and modified the waptserver.ini file to change the parameter name, and even after rebooting, the problem remains the same.
January 10, 2025 - 2:05 PM
Can you test this script?
/opt/wapt/waptserver/scripts/testing-ldap-connectivity.sh
t.heroult
January 10, 2025 - 2:06 PM
Result:
{'success': False, 'groups': [], 'error': False, 'msg': 'Kerberos EGssApi: Failed to acquire credentials for specified user - Unspecified GSS failure.  Minor code may provide more information'}
January 10, 2025 - 2:11 PM
Can you run `
kinit username?
--> password`?
What is the Wapt configuration at the LDAP level? (IP address, not server address?)
t.heroult
January 10, 2025 - 2:25 PM
kinit:
It asked for the password, I entered it and it returned to the prompt without further information (in any case, no error message)
Config:
In the waptserver.ini, the ldap_auth_server is in name, not in IP.
January 10, 2025 - 2:40 PM
And the name does indeed correspond to a DC?
otherwise you can delete
ldap_auth_server
ldap_auth_base_dn
and leave only:
ad_domain_name = ad.mydomain.lan
wapt_admin_group = waptadmins
In this way, if the site and service are properly configured, the Wapt server will act like a Windows client, making a clap request to automatically find the correct domain controller.
In case of AD migration, name change, etc., WAPT will automatically resume working ;)
t.heroult
January 10, 2025 - 3:23 PM
Yes, this is indeed the main DC.
The configuration is exactly the same as with the second WAPT server (previous version), which does not present any access problems.
t.heroult
January 10, 2025 - 3:30 PM
Okay, I found it.
When I renamed the "wapt_admin_group" parameter, I left the value as "dn"...
I changed it to samaccountname and rebooted, and it's working.
It's a shame it didn't happen during the update ;)
. Thanks for your help!
