Problem installing packages on a computer
Answer
Mikael_S
Registration: Apr 25, 2023 - 11:57
December 20, 2024 - 9:30 AM
Agent version: WAPTSetup 2.5.5.15640
For some time now, I've had a computer that can no longer install any packages. I get the same error on all of them:
FileNotFoundError: [Errno 2] 'Le fichier spécifié est introuvable'
2 : 'Le fichier spécifié est introuvable'
On the machine package, I therefore have the following problem:
EWaptUnavailablePackage: Missing dependencies:
I reinstalled the agent, removed the remaining directories, and deleted the machine from the console: same result
The packages were successfully retrieved from the workstation
Could it be a registry key?
January 16, 2025 - 5:38 PM
Hello Mikaël,
I don't really have any idea... What happens if you run an upgrade in debug mode?
wapt-get upgrade -ldebug
Answer
