We have enabled WUA on the WAPT agent.
The problem is that the PCs retrieve updates from the internet but not from the server.
The updates are indeed downloaded to the server.
Server: Linux Debian (2.6)
Secondary repositories: Linux Debian (2.6)
Console installed on server 2022
[SOLVED] WUA Problem
Here is the configuration file:
[global]
use_hostpackages=1
use_kerberos=0
use_fqdn_as_uuid=1
use_ad_groups=1
use_repo_rules=1
allow_remote_reboot=1
allow_remote_shutdown=1
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
repo_url=https://srv-wapt/wapt
wapt_server=https://srv-wapt
verify_cert=C:\Program Files (x86)\wapt\ssl\server\srv-wapt 20240718-1505.crt
include_dmi_inventory=1
include_wmi_inventory=1
peercache_enable=0
[waptwua]
enabled=1
default_allow=0
install_delay=
download_scheduling=
install_at_shutdown=1
install_scheduling=I see you're using a secondary repository. Is the machine supposed to depend on this secondary repository?
If so, the repository URL in the rule isn't http://download.windowsupdate.com/micro ... 6/wsusscan, I hope.
The latest build 2.6.0.16937, released on February 13th, contains many fixes related to waptwua: (https://www.wapt.fr/fr/doc/wapt-changel ... -2-6-serie). Is this the installed version?
- WAPT Expert
Hi Farid,
thanks for the feedback.
I'm marking the topic as resolved.
