WAPT Exit Error
Answer
smandel
Registration: May 5, 2022 - 11:30
February 27, 2025 - 2:31 PM
I have several computers that display a WAPT error upon restart/shutdown:
"none" is not a valid boolean. Press "OK" to ignore and risk data corruption. Press "abandon" to close the program.
Thank you.
February 27, 2025 - 4:40 PM
Can you provide your wapt-get.ini file?
It seems that a string "none" is being detected.
smandel
February 27, 2025 - 4:44 PM
Indeed...
[waptwua]
enabled=True
default_allow=True
install_delay=
download_scheduling=2h
install_at_shutdown=None
install_scheduling=1d
filter=Type='Software'
In fact, the "install_at_shutdown" field no longer exists in the configuration editor, and that must be why it's set to "None"
March 3, 2025 - 09:49
install_at_shutdown
Cannot be None since it is a boolean
How did this parameter get here?
Note: in the latest version of wapt this parameter no longer exists.
smandel
March 4, 2025 - 11:05
Since the field no longer exists, I suspect the package editor is setting it to "None" because it still appears in the configuration.
I manually deleted the field from "saved properties" to resolve the issue.
Answer
