The 'user' variable during package installation
Murasakiiru
Registration: Nov 15, 2016 - 6:11 p.m.
November 15, 2016 - 6:30 PM
I'm trying to create a package with Wapt, and I'd like to send files to the User folder.
I tried using the user_appdata variable, which seemed like a good idea, but it keeps returning this error:
Otherwise, I tried `os.getenv(USERPROFILE): C:\Windows\system32\config\systemprofile`
or `os.getenv(USERNAME):`: returns my machine name and not my username.
I'm a bit stuck here. I understand that the commands are executed with the 'SYSTEM' user, hence the output I'm getting, but how do I fix this?
Thanks,
Mura.
EDIT: More descriptive title
Aguay
Registration: May 22, 2015 - 4:20 p.m.
November 16, 2016 - 5:07 PM
are you targeting a specific user?
Or do you want to deploy something to all users on the machine?
You might want to check out https://dev.tranquil.it/sphinxdocs/sour ... local_users.
You'll certainly find other useful information there. ;)
And if you still can't find what you're looking for and/or don't know how to proceed, feel free to repost. :)
Good luck!
November 21, 2016 - 4:20 PM
To customize the installation of software in the user's context, a function must be added
session_setup
add to your package and include the additional actions
example :
    # system wide
    run('...')
def session_setup():
    # un raccourci personnalise...
    create_user_desktop_shortcut('Navigateur pour %s'%get_current_user(), target = makepath(programfiles32,'Mozilla Firefox','firefox.exe'))
