Secondary Repository Status TO UPDATE
Answer
Vercingetorix
Registration: Sep 19, 2024 - 09:09
February 28, 2025 - 11:11
Wapt 2.6.0.16881 we migrated from 2.5 to 2.6.
We can synchronize the wapt packages, but not the drivers for wads, not waptwua.
The connection status is OK
The sync status remains at: to Update
The "force the sync" has no effect.
No trace in the logs.
How can we force synchronization from the server via the command line?
We can clearly see on the secondary server that the directory C:\Program Files (x86)\wapt\repository\wapt\wads\drivers is not full, missing files for example.
wapt-get.ini
[global]
use_hostpackages=1
repo_url=https://xxx-xxx-xxx/wapt
wapt_server=https://xxx-xxx-xxx
verify_cert=0
max_gpo_script_wait=180
pre_shutdown_timeout=180
hiberboot_enabled=0
use_repo_rules=1
allow_remote_reboot=1
allow_remote_shutdown=1
send_usage_report=1
use_kerberos=0
peercache_enable=0
use_ad_groups=1
[wapthttpserver]
root_dir=C:\Program Files (x86)\wapt\repository
http_port=80
https_port=443
cert_file=C:\Program Files (x86)\wapt\wapthttpserver\ssl\cert.pem
private_key_file=C:\Program Files (x86)\wapt\wapthttpserver\ssl\key.pem
enable_logging=1
[repo-sync]
enable_remote_repo = True
local_repo_path = C:\Program Files (x86)\wapt\repository\wapt
local_repo_time_for_sync_start = 20:00
local_repo_time_for_sync_end = 05:30
local_repo_sync_task_period = 25
local_repo_limit_bandwidth = 4
remote_repo_dirs = wapt,waptwua,wads,wapt-host
March 3, 2025 - 09:48
on the secondary repository you can delete the sync.json file which is usually located in /var/www or /opt/wapt/repositories (depending on your configuration).
Then restart the waptservice. The service will then perform a full scan of the locally stored files and re-download any missing files.
This may take a while, but it resets the repository.
Vercingetorix
March 3, 2025 - 3:07 PM
indeed, deleting the sync.json file restarts the file resynchronization.
It seems to me that everything is present.
However, the synchronization status remains orange at: TO UPDTAE.
And the status is SYNC_FINISHED.
How can I change the synchronization status?
Thank you in advance.
Vercingetorix
March 7, 2025 - 08:16
we have upgraded Wapt from version 2.6.0.16881 to Wapt 2.6.0.16937. The synchronization status is now OK.
We can now mark the ticket status as resolved.
Have a good day.
Answer
