[SOLVED] Installing the previous version of a package
VincentUCA
Registration: Oct 25, 2023 - 2:49 p.m.
March 19, 2025 - 11:56
WAPT version 2.6
Sorry if a similar topic has already been opened, I couldn't find it.
I'm currently developing a software package whose installer doesn't remove the old version. So I added a piece of code to do that. But for testing purposes, I'd like to be able to reinstall the old version. I think I've done this before, but I didn't take notes and I've since forgotten how.
I found a section in the documentation stating:
Each command that takes a package name as a parameter can also take the package's unique package_uuid as a parameter (wapt-get install, wapt-get forget, etc.). Using a GUID allows you to specify a unique package without ambiguity about its architecture or version. The package_uuid is listed in the output of wapt-get list and wapt-get search. For example:
So I made a
wapt-get search monpaquet
to retrieve the package ID in the version I'm interested in.
But then when I execute the command
wapt-get install c65ecfc2-ed87-428a-abc7-1646497ee71e
I get the following error:
install using WAPT packages c65ecfc2-ed87-428a-abc7-1646497ee71e
Results:
Critical:
=== Unavailable packages ===
c65ecfc2-ed87-428a-abc7-1646497ee71e [x64_fr_PROD,DEV,PREPROD]
Where am I going wrong?
Thank you in advance for your reply.
Sincerely.
Vincent
March 20, 2025 - 09:42
Hello Vincent,
You can force the installation of a particular version using the following syntax:
wapt-get install "tis-monpaquet(=2.5.3)"
However, the version "pinning" is not stored in the agent, and therefore the package will be updated at the next wapt-get upgrade.
vcardon
March 20, 2025 - 7:46 PM
Hello, to follow up on Denis's comment, if you want a version of a software without it updating, duplicate the version you're interested in and rename the package with the software version.
For example: the tis-firefox package for version 136.0.2 would become tis-firefox-pinned-136.0.2.
VincentUCA
March 21, 2025 - 11:34
Hello everyone,
Thank you for your valuable advice. I successfully tested the installation of an older version of my package. However, the part added by WAPT must not be omitted from the version number, otherwise it won't work. To use the previous example, it looks like this:
wapt-get install "tis-monpaquet(=2.5.3-2)"
I suggest removing the installation via the UUID of a package from the documentation if it no longer works and adding this method via version "pinning" which I have not been able to find elsewhere.
To be perfectly honest, the package I'm trying to develop is for the Chimera software. A package already exists in the tranquil.it repository with the code to uninstall previous versions, but I've noticed two things.
The first issue is that the Chimera software version number is not recorded in the Windows registry. Therefore, the package code is as follows:
for to_uninstall in installed_softwares("UCSF Chimera"):
        if Version(to_uninstall["version"]) < Version(last_version):
Always test the condition:
if 0.0.0.0 < N° de la dernière version:
Therefore, regardless of the version installed, it will be uninstalled.
The second issue is that the `installed_softwares("UCSF Chimera")` function also retrieves the ChimeraX registry key, which also lacks a version number. This results in ChimeraX being uninstalled during the Chimera installation process.
I saw that in the Chimera uninstallation registry key, the version number was indicated in the "DisplayName" key. Therefore, I modified the code as follows:
        to_uninstall_version = to_uninstall["name"].split()[-1]
        if Version(to_uninstall_version) < Version(last_version):
            print(f"Removing: {to_uninstall['name']} ({to_uninstall_version})")
The tested conditions become:
if 1.18.0.0 <1.19.0.0:
And
if "ChimeraX"<1.19.0.0:
Because ChimeraX does not have the version number included in "DisplayName", this condition appears to return False.
It's not the cleanest solution, but it works. The latest version of Chimera isn't uninstalled and then reinstalled when the package is updated without changing the software version, and ChimeraX isn't uninstalled either, allowing both software packages to coexist. I admit it's a bit of a nitpick :oops: Because now that I've added the function to remove the desktop shortcut, I don't think I'll touch the code of this package. And normally there's little point in having Chimera and ChimeraX installed on the same machine, but apparently there are functions that were removed from Chimera in ChimeraX that are useful for some users.
Thank you again for responding to my request.
Sincerely.
Vincent
March 21, 2025 - 2:11 PM
Hi Vincent,
thanks for the feedback. I'm forwarding your post to the team that maintains the store packages so they can fix the package following your advice. :-)
Regards,
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
March 24, 2025 - 11:10
I've just adapted the code so that an already installed version of ChimeraX isn't uninstalled along with Chimera. Indeed, the version check wasn't working; I've also modified that.
Thank you for bringing this to our attention.
Ingrid
