[RESOLVED] WUA error KB5050021
March 24, 2025 - 4:47 PM
contact our support team and we'll take a look.
gavit
Registration: Apr 30, 2020 - 4:21 p.m.
March 24, 2025 - 5:49 PM
Thank you, I'll call you tomorrow around 2pm
gavit
March 27, 2025 - 10:28
Hello Simon,
Thanks for your help, it fixed 95% of the park.
We just have this one mistake left that I need to correct.
0x80246fff "There was a download manager error not covered by another WU_E_DM_* error code."
I'm really looking forward to the addition of a shortcut to clean up the Software Distribution folder ;)
gavit
March 27, 2025 - 4:05 PM
We executed the following commands on the server:
Disable the wapttasks service
sudo systemctl stop wapttasks
Connecting to the Wapt psql database
sudo -u wapt  psql
psql (15.12 (Debian 15.12-0+deb12u2))
Type "help" for help.
wapt=> delete from  wsusupdates  WHERE download_urls::TEXT LIKE '%filestreamingservice%';
	DELETE 38
wapt=> delete from wsusdownloadtasks;
	DELETE 3272
wapt=> \q
Deleting .sqlite files without /opt/wapt/db/
sudo rm -f /opt/wapt/db/*.sqlite
Service restart
sudo systemctl restart wapttasks
March 28, 2025 - 11:34
Hi Gaëtan,
thanks for the feedback. :-)
We'll soon be releasing a new version of wapt that should prevent the wapttasks database from becoming overloaded with "filestreamingservice" URLs. We're also looking into adding a task to clean up the softwaredistribution directory directly in the console. In this new version, we've added some things to improve 24h2 update support (I don't know if even Microsoft engineers still understand how it works...).
I'm marking this topic as resolved.
See you soon,
