Package update
Answer
Mathis
Registration: Nov 23, 2022 - 08:53
March 31, 2025 - 5:24 PM
I recently upgraded my WAPT.
I now develop my packages using VS Code.
When I run "WAPT - Build Package", it doesn't work. I switched from PyScripter to VS Code thinking it was due to my Python version, but the problem persists. I get the error
"ERROR: Unknown action build-package".
I thought I saw on the forum that package editing is now only done from the console?
Thank you.
Server OS: Windows Server 2022
Admin Machine OS: Windows 10 22H2
WAPT Version: 2.6.0.16937
March 31, 2025 - 10:35 PM
Good morning
Mathis wrote: March 31, 2025 - 5:24 PM I thought I saw on the forum that package editing is now only done from the console
Yes, absolutely, to avoid "context" problems, the build is now done entirely through the console.
Mathis
April 1, 2025 - 2:55 PM
How can I create empty packages? Whenever I try to create an empty package, I'm redirected to VS Code to edit the build.
Second question:
Is it possible to disable VS Code or Python from launching when I click "Edit Package Basket"?
Thank you.
April 4, 2025 - 9:23 AM
When you create (or edit) a package, the console creates an empty shell and launches the code editor specified in the console preferences (
pyscripter, vscode, or another)
If you don't want to use an editor and you place C:\Windows\explorere.exe in its place, it should simply open a file explorer window to the location of the shell.
Answer
