[SOLVED] readstring registry function
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
April 3, 2025 - 11:01
I'm having trouble accessing a specific registry:
Are you able to run this command?
 registry_readstring(HKEY_LOCAL_MACHINE, 'SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\State\\Machine\\Scripts\\Shutdown\\0\\0','Script')
I always get an empty result.
The command does work on the top tree, for example
registry_readstring(HKEY_LOCAL_MACHINE, 'SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\State\\Machine\\Scripts\\Shutdown\\0','DisplayName')
Similarly, if I use reg_key_exists, the function has a specific return value:
reg_key_exists(HKEY_LOCAL_MACHINE, 'SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\State\\Machine\\Scripts\\Shutdown\\0')
Returns True
but
reg_key_exists(HKEY_LOCAL_MACHINE, 'SOFTWARE\\Microsoft\\Windows\\CurrentVersion\\Group Policy\\State\\Machine\\Scripts\\Shutdown\\0\\0')
Returns
  File "<console>", line 1, in <module>
  File "C:\Program Files (x86)\wapt\waptutils.py", line 2786, in reg_key_exists
    with reg_openkey_noredir(rootkey, subkeypath):
AttributeError: __enter__
Any idea why this behavior occurs?
THANKS !
Good day,
guigeek
April 3, 2025 - 11:53
Sorry, I just saw it was a permissions issue.
It works as an admin.
April 4, 2025 - 12:56
Hello Guillaume,
guigeek wrote: Apr 3, 2025 - 11:53 Sorry, I just saw it was a permissions issue.
It works as admin.
No worries, it happens to the best of us ;)
