Package KB5002623
Answer
Gaetan
Registration: August 8, 2019 - 10:16
April 10, 2025 - 4:15 PM
For the problem related to KB5002700 in Office 2016, Microsoft indicates to use the binary here: https://www.microsoft.com/en-us/downloa ... ?id=108113
Here is a package code to manage 32-bit and 64-bit Office:
r"""
# Info : https://www.microsoft.com/en-us/download/details.aspx?id=108113
#Outlook uninstallkey :
#32 bits
#{90160000-0012-0000-0000-0000000FF1CE}
#64 bits
#{90160000-0012-0000-1000-0000000FF1CE}
    # Declaring local variables
    office_version = installed_softwares("Office")
    # Installing the software
    for key in office_version:
        if ("90160000-0012-0000-1000-0000000FF1CE" in key["uninstall_string"]):
            print("Installing")
            install_exe_if_needed('msodll202016-kb5002623-fullfile-x64-glb.exe',
                silentflags='/quiet',
                key='',
                min_version='16.0.5495.1002'
            break
        elif ("{90160000-0012-0000-0000-0000000FF1CE}" in key["uninstall_string"]):
            print("Installing")
            install_exe_if_needed('msodll202016-kb5002623-fullfile-x86-glb.exe',
                key='',
            break
            print("Office version is not 2016 version")
esberard
Registration: Oct 09, 2023 - 11:35
April 10, 2025 - 6:07 PM
We manage with this package as a dependency of our Office 2016 package:
    # Retrait kb KB5002700 Office avril 2025
    if WAPT.installed('unistra-ms-office2016'):
        if installed_softwares('02350708-7ECD-44B8-A8D0-62BEBB7B5847') and not installed_softwares('FCD65F48-B92B-4238-818C-72FC256E8E23'):
            print("KB5002700 installée sans kb5002623 : application du correctif")
            run_notfatal('msodll202016-kb5002623-fullfile-x86-glb.exe /quiet /norestart')
        elif installed_softwares('FCD65F48-B92B-4238-818C-72FC256E8E23'):
            print('Correctif kb5002623 déjà appliqué')
            print('KB5002700 manquante')
        print("Office 2016 n'est pas installé. Non géré")
def audit():
    retour = 'OK'
            print("ERREUR : le correctif n'est pas actif\nRéinstallation du paquet")
            retour = 'ERROR'
            WAPT.install(control.package, force=True)
    return retour
Gaetan
April 11, 2025 - 11:46
A small correction for those who already have the KB:
r"""
# Outlook uninstallkey :
# 32 bits
# {90160000-0012-0000-0000-0000000FF1CE}
# 64 bits
# {90160000-0012-0000-1000-0000000FF1CE}
    kb_installed = installed_softwares("kb5002623")
    if not kb_installed:
            if "90160000-0012-0000-1000-0000000FF1CE" in key["uninstall_string"]:
                print("Installing")
                    "msodll202016-kb5002623-fullfile-x64-glb.exe",
                    silentflags="/quiet",
                    key="{90160000-0012-0000-1000-0000000FF1CE}_Office16.STANDARD_{15F938CC-D683-433E-B300-C3B15EC3F6DB}",
                    min_version="16.0.5495.1002",
                break
            elif "{90160000-0012-0000-0000-0000000FF1CE}" in key["uninstall_string"]:
                print("Installing")
                    "msodll202016-kb5002623-fullfile-x86-glb.exe",
                    key="{90160000-0012-0000-0000-0000000FF1CE}_Office16.STANDARD_{FCD65F48-B92B-4238-818C-72FC256E8E23}",
                break
        print("kb5002623 Already installed")
Answer
