[RESOLVED] Since version 2.6.0.17177, PXE boot is no longer possible
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 11, 2025 - 3:03 PM
since the last update, it's impossible to use WADS; the machines can't find a PXE server.
The wapttftpserver.service is running correctly, and I can't find any error messages.
There's simply no response from the TFTP server.
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
April 11, 2025 - 3:59 PM
Hi Thomas,
is the wapttftpserver service running correctly? Is it on the main server, not a secondary repository? Could you please provide the command line you get with `ps -edf | grep tftp`?
Simon is running a series of internal tests.
Regards,
t.heroult
April 11, 2025 - 4:02 PM
The wapttftpserver service, I said it was OK in the initial post.
There is no secondary repository.
I did a telnet "server wapt" 69 from another machine and there is no listening.
Result of the command executed on the WAPT server:
wapt         510       1  0 15:05 ?        00:00:00 /opt/wapt/wapttftpserver.bin --fork --username=wapt --root_dir=/var/www/wads/pxe --verbose
April 11, 2025 - 4:07 PM
Hello again Thomas,
t.heroult wrote: Apr 11, 2025 - 4:02 PM The wapttftpserver service, I said it was OK in the initial post.
I was talking about the binary itself, not the systemctl status
I telneted "server wapt" 69 from another machine and there is no listening.
That's normal, it's UDP. You can test it with a TFTP client on the client
apt-get install tftp-hpa
tftp 127.0.0.1
tftp> binary
tftp> get ipxe.efi
Simon has managed to reproduce the problem; we'll get back to you shortly. You can retrieve the previous version of wapttftpserver.bin; there is indeed a regression related to log management, apparently...
Sorry,
t.heroult
April 11, 2025 - 4:09 PM
OK, thank you, I'll wait for the reply :)
April 11, 2025 - 4:13 PM
Hello again Thomas,
The problem has been fixed internally; we'll release a version for this bug sometime this week. In the meantime, you can revert to the previous version of the wapttftpserver.bin binary until we release the update.
wget https://wapt.tranquil.it/wapt/releases/wapt-2.6.0.16937-7ba7ea7a/bin/linux-x64/wapttftpserver
mv wapttftpserver  /opt/wapt/wapttftpserver.bin
chmod a+x /opt/wapt/wapttftpserver.bin
systemctl restart wapttftpserver
Regarding this glitch, the TFTP server we're using in the continuous integration environment is indeed a wapttftpserver, but not the one from the Wapt server currently being tested for WADS (for various technical and historical reasons). Furthermore, the Wapt binaries hadn't been updated on the machine in question, which serves as the TFTP server for this continuous integration VLAN. We'll try to correct this to prevent it from happening again.
Sorry, sincerely,
t.heroult
April 15, 2025 - 09:16
Hi,
thanks for the feedback.
I'll wait for the next release. This week we're shutting down the factory, so we're fully focused on the servers!
Mastering the PCs will have to wait. Have :D
a good day!
clafon
Registration: Nov 06, 2024 - 10:56
April 25, 2025 - 09:03
when is the next release scheduled to fix this issue? Thank you.
April 25, 2025 - 09:23
version 2.6.0.17226 was released yesterday.
