I'm trying to create a query that lists packages that install the same software (any version, any software, not one in particular)...
thank you for your help
[RESOLVED] Duplicate packages
- WAPT Expert
Hello Renaud,
to do this you will need to have a standardized list of installer references using the "Software Inventory" tab, "Standardized" column [1]. Then you can take inspiration from queries [2] or [3].
Regards,
[1] https://www.wapt.fr/fr/doc-2.6/wapt-con ... ware-names
[2] https://www.wapt.fr/fr/doc-2.6/wapt-con ... ware-query
[3] viewtopic.php?t=1840
Regards,
