batch script error 11
Stenon
Registration: June 2, 2016 - 8:04 AM
November 22, 2016 - 3:11 PM
Hi,
I'm having a small error that's bothering me:
CalledProcessError: Command '('installnet.bat',)' returned non-zero exit status 11.
The goal is to install .NET 3.5 on Windows 10...
the following command in the admin console works fine:
C:\Windows\System32\Dism.exe /online /enable-feature /featurename:NetFx3 /All /Source:.
I put
in my WAPT package. I do have the dotNet.cab file that's needed (which I reference with /Source:).
If you have any ideas, I'm all ears. I've already tried the package from the internet, but that doesn't work either (tis-dotnet35).
Many thanks!
**Additional info
setup.py:
uninstallkey = [""]
run('installnet.bat')
installnet.bat:
@echo off
C:\Windows\System32\Dism.exe /online /enable-feature /featurename:NetFx3 /All /Source:. /LimitAccess
