Error creating WAPTAGENT
avondra
Registration: Nov 9, 2016 - 12:02
November 21, 2016 - 5:39 PM
making slow but steady progress...
I'm now encountering an error during package installation:
The clients are correctly installed via GPO and are reporting correctly, but when installing the packages, I get this message: `
File "C:\Program Files (x86)\wapt\common.py", line 2430, in update_host
host_package_date = httpdatetime2isodate(host_request.headers.get('last-modified',None))
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 3557, in httpdatetime2isodate
return datetime2isodate(datetime.datetime(*email.utils.parsedate(httpdate)[:6]))
TypeError: 'NoneType' object has no attribute '__getitem__'`
Do you have any ideas?
Thanks
avondra
November 22, 2016 - 10:25
I suspect the problem I'm encountering is still related to the installation path in the Windows "Program Files (x86)" directory. Do all Python files need to be patched?
This message appears when I double-click the client on which I want to apply software deployment or updates.
I thought that support for the "Program Files (x86)" directory was integrated into current versions of WAPT.
Am I mistaken?
Thank you for your help,
Alain
November 22, 2016 - 2:47 PM
I think this is a different type of bug, unrelated to spaces in the program files path.
The /var/www/wapt-host directory doesn't contain the Packages index.
I suggest you run the following command on the server:
python /opt/wapt/wapt-scanpackages.py /var/www/wapt-host
, which should create an empty Packages file.
avondra
November 22, 2016 - 5:06 PM
I successfully ran the Python command, but for /var/www/html/wapt-host, I now have an icons/ directory and a Packages file. However, I still get this error when I double-click on a machine:
Have I missed something?
Thank you.
November 25, 2016 - 7:29 PM
Currently, wapt has difficulty functioning in the Program Files directory.
This will be fixed in future versions.
For now, it is best to install wapt in c:\wapt
avondra
November 26, 2016 - 8:35 PM
I reinstalled it in C:\wapt and I'm getting the same result....
November 27, 2016 - 03:07
The problem clearly stems from here:
https://github.com/tranquilit/WAPT/blob ... ge.py#L132
According to your message...
it seems to be a problem with `httpdatetime2isodate(httpdate)`.
The function converts a date string as returned in HTTP headers or mail headers to an isodate.
There might also be an issue retrieving the modification date from your Packages file.
I haven't been able to reproduce your problem myself.
avondra
November 28, 2016 - 6:26 PM
as advised, I generated the Packages file, which didn't exist, using the command:
python /opt/wapt/wapt-scanpackages.py /var/www/wapt-host.
Could this be the cause of the error?
Thank you for your help.
November 28, 2016 - 6:55 PM
Which version of Wapt do you have?
avondra
November 29, 2016 - 10:28
Version 1.3.8
