[RESOLVED] Packet deployment rule
gch14800
Registration: July 23, 2024 - 09:01
April 28, 2025 - 2:45 PM
I was wondering if it's possible to set specific rules for packages in order to, for example:
- Block the installation of a package on a specific brand of computer (or conversely, only allow installation on a specific brand)
- Allow or block package installation based on the computer model.
The goal is to be able to create a list of packages per OU (Organizational Unit), so if I have an ASUS PC and not a Dell, I don't install Dell updates. For example, I would have several examples, particularly regarding drivers and other things.
Any ideas?
Thanks in advance.
blemoigne
Registration: July 17, 2020 - 11:29
April 28, 2025 - 4:12 PM
You can use a "meta-package" which will install other packages under certain conditions. Example:
	if host_info()['system_manufacturer'] == 'LENOVO':
		WAPT.install('tis-paquet-lenovo')
Have a good rest of the day
Bertrand
