[SOLVED] KiCad 9 new package
Olivier Schmitt
Registration: Oct 22, 2024 - 1:25 p.m.
April 25, 2025 - 4:09 PM
Hello dear TIT TEAM and all,
As already discussed, the KiCad software operates based on major versions.
Currently, you have version 7, version 8, and version 9 has been released.
To help you quickly create tis-kicad9, I have:
-Downloaded version 8
-Replaced if "8.0" in data["name"]: with if "9.0" in data["name"]: at line 25 of update_package.py
-Tested and validated the updatepackage function, it's ok
-Tested and validated the installation, it's ok
-For uninstallation, I will report the issue on their git that their QuietUninstallString command "C:\Program Files\KiCad\9.0\uninstall.exe" /allusers /S does not seem to work.
Could you create this new package for version 9?
Thank you in advance.
Olivier Schmitt
April 25, 2025 - 4:17 PM
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
April 28, 2025 - 3:48 PM
When I test this software version on my computer, even with a system account, I don't have any problem. However through LUTI I have an error but I don't have any logs, perhaps it is an uninstallation issue.
Do you have any error/logs when you try to uninstall?
Many thanks.
Ingrid
Olivier Schmitt
April 29, 2025 - 12:16
Hello Ingrid,
Thank you for your feedback.
They actually switched to a new installer in the meantime, and it does not produce uninstallation logs.
It seems they did not properly implement install silently on the new uninstaller.
Best regards,
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
May 13, 2025 - 4:37 PM
Hi,
Kicad has released a new version that does not provide any error.
Luti has passed all the tests: https://luti.tranquil.it/listfolder/825 ... b12b7713ea
You can find the package right here: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Or you can wait 5 days before it's available directly in the store.
Best regards,
Joffrey
