I have a script that runs when the network connection changes and checks if the connection is local or not.
If it's local, it changes the WAPT configuration, disabling the `waptwua` field so the PC can access the internet to perform updates.
This all worked fine before version 2.6.0.171177, but since then, when I disable the `waptwua` field, it's still impossible to run Windows updates.
Is this normal? Is it a new feature or a bug?
Thank you for your feedback,
Guillaume
Disable waptwua
Set the following four keys to 0:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\DisableWindowsUpdateAccess
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\AU\UseWUServer
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\SetDisableUXWUAccess
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\DoNotConnectToWindowsUpdateInternetLocations
Run gpupdate /force
Restart the “Windows Update” service
Have a good day,
Bertrand
Run gpupdate /force
Have a good day,
Bertrand
Thanks! I tried that, I can access the update button, but then I get an error as if the update service is unavailable:
"We couldn't connect to the update service. We'll try again later, or you can check now. If it still doesn't work, make sure you're connected to the internet."
I must be missing something for it to work because the PC has internet access.
"Restart the Windows Server 10 (WU) service.
In the command prompt (CMD), run:
`wuauclt /resetauthorization /detectnow /reportnow`.
run
`USOclient refreshsettings`
scan. Then refresh and retry in the Windows Server 10 settings pane."
I found this on a forum. The three commands are independent.
run
- WAPT Expert
when waptwua is enabled, it configures the registry keys here:
and at:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\WindowsUpdate
and disables the Windows Update service.
Therefore, when waptwua is disabled, the process is reversed.
If the key HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate\SetDisableUXWUAccess = 1 and waptwua is "disabled",
then delete the keys
and HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
, and then restart the Windows Update service.
Normally, in your use case, I would strongly recommend using secondary download rules.
You can tell the computer to use http://download.windowsupdate.com/micro ... /wsusscan/ with a secondary download rule.
and at:
