I like the new interface features, especially the more detailed WUA status, but there's a problem.
A lot of new columns have appeared in the main interface. And when I remove them and close the console, they reappear!
In short, the changes I make to my interface aren't saved. Yet the file "C:\Users\xxx\AppData\Roaming\waptconsole\waptconsole.ini" is definitely up to date (at least the modification date).
Any idea what's wrong?
[RESOLVED] New console: not saving interface changes
Server: WAPT Enterprise 2.6.1.17786 on Debian
Consoles: Windows 10 & 11
Infrastructure: Windows
I just installed the latest version (2.6.0.17289) and the problem persists.
When I close the console and reopen it, I'm faced with a bunch of columns I don't want. It's always the same ones, some I created previously and others that are default.
It's impossible to customize the interface; it's becoming really frustrating!
I'll investigate.
But if it's a regression... it could be due to this commit:
https://github.com/tranquilit/pltis_sog ... 7110632cb9
I'll do a build reverting this change and submit it to you for validation, if you don't mind.
Hubert
I'll investigate.
Hubert
No problem, I'm available to test it
Hello Hubert.
I'm returning to this topic.
I confirm that with version 2.6.0.17343, the problem is solved.
