I'm having a problem deploying the latest wapt client (3 weeks ago). Several hundred of my PCs successfully updated the wapt-upgrade package to version 1.3.8, but with the following message:
Your current wapt version (1.3.5.0) is too old to be upgraded, a full waptagent.exe install will be planned for Mon Nov 07 17:11:43 2016
waptexit is running, scheduling a one time task at system startup with command c:\windows\temp\waptdeploy.exe --hash=e9920bc1e5502f846a90715457e281b009d77aa2a79c2eda1180e296006206ac --waptsetupurl=c:\windows\temp\waptagent.exe --wait=15 --temporary --force --minversion=1.3.8.2
Information?: la t?che planifi?e "fullwaptupgrade" sera cr??e sous le nom d'utilisateur
("AUTORITE NT\SYSTEM").
Op?ration r?ussie : la t?che planifi?e "fullwaptupgrade" a ?t? cr??e.And on approximately 90 PCs, I still have client 1.2.3.2 active with the following message after installing the latest wapt-ugrapde package:
Your current wapt version (1.2.3.2) is too old to be upgraded, a full waptagent.exe install will be planned for Tue Jul 05 10:16:31 2016
waptexit is running, scheduling a one time task at system startup with command c:\windows\temp\waptdeploy.exe --hash=e7deadf35ba854c8a25f47c49fa7f5dbd93dcbc927db64abc18ada354ffb526c --waptsetupurl=c:\windows\temp\waptagent.exe --wait=15 --temporary --force --minversion=1.3.5.0
Erreur?: Impossible de cr?er un fichier d?j? existant.
Erreur?: la t?che "fullwaptupgrade" ne fonctionnera peut-?tre pas car les informations de compte ne peuvent pas ?tre d?finies.
INFO?: le fichier de t?ches v1 est en cours de suppression.
