Hello everyone,
Here is some information:
WAPT version: 2.5.5.1569, Enterprise Edition
WAPT Server: Windows Server 2019
Administration machine: Windows 11
I am posting my question on this forum after numerous searches that have yielded no solution.
I want to deploy operating systems on a fleet of PCs, both old and new.
The deployment process seems to be starting well: the PC boots via the network (PXE), the WADS interface displays correctly.
I enter my WAPT credentials, then I assign a name to the machine. It correctly appears in the WAPT console, in the "OS Deployment" section.
I then assign it a deployment configuration, and then I launch the deployment.
The ISO download seems to go smoothly, but then the process gets stuck at the "WAPT Installation Completed" stage.
Has anyone else encountered this problem or have any suggestions for resolving this issue?
Thank you in advance for your help!
[RESOLVED] Stuck during OS deployment
- WAPT Expert
Hello
, that's strange behavior.
I see you're still using Wapt version 2.5. Could you try upgrading to Wapt version 2.6?
Atlantis10
- Registration: May 15, 2025 - 11:40
indeed, it was simply a matter of updating WAPT.
Thank you for your help.
