Disable waptwua
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
May 21, 2025 - 11:26
Thank you for these answers!
guigeek
June 6, 2025 - 4:10 PM
I'm still having problems.
Since version 2.6, even after uninstalling the WAPT client, I can no longer update the PC directly.
I've tried deleting the registry entries, but nothing changes.
I can access the update button again, but it just searches indefinitely and never completes.
I have the impression that it works with PowerShell.
Any idea what the problem could be?
Thanks
June 11, 2025 - 3:18 PM
Good morning
I just did a round trip test of
[waptwua]
enabled=True
restart service
Then:
[waptwua]
enabled=False
restart service
The scan is working.
Is the tis-fix-disable-windows-update package not installed on the machine?
Answer
