Console Function Update-package
aureladmin
Registration: December 4, 2024 - 9:41 AM
June 20, 2025 - 11:59
I'm trying to use the "Windows 11 Upgrade Template" package. I'm following the steps in the YouTube video, but I'm stuck at the point where I have to launch the update package. The option is grayed out in the console. Do you have any idea why, or a workaround?
PS: Image of the grayed-out function attached.
Regards
WAPT Discovery 2.6.0.17293
Debian 12 / Ubuntu 22.04
aureladmin
June 20, 2025 - 3:08 PM
If I try to do it via the command line, it works up to "Build Upload" where I get the error "status: 666".
I don't know what to do. If anyone has any ideas, I'd appreciate it.
blemoigne
Registration: July 17, 2020 - 11:29
June 20, 2025 - 4:41 PM
Updating packages via the console seems to be a restriction in Discovery Edition.
But the `wapt-get update-package-sources` command works correctly?
And then the build-upload is done from the console?
Bertrand
aureladmin
June 20, 2025 - 5:41 PM
`waptpython "C:\Program Files (x86)\wapt\wapt-get.py" update-package-sources "C:\waptdev\epl-windows11-upgrade-template_0-115_x64_windows_6.1_PROD-wapt"
` works correctly (from the command line) via cmd.
However, when I try to build and upload from the console, I get an error.
Even with error (666), the package is present in the repository, so I'm trying to figure out how to bypass the error. If that doesn't work, I'll try a build and upload from the command line.
aureladmin
June 23, 2025 - 10:26
Same error on the command line. The build is OK, but not the upload.
Could you please provide the prerequisites for using the "windows11-upgrade-template" package?
Speaking of prerequisites, I'd like to know which module needs to be enabled on the WAPT server. Currently, I only have software deployment enabled. For example, is "OS deployment" required even without an enterprise license?
Or does the "windows11-upgrade-template" package only work with an enterprise license?
blemoigne
June 23, 2025 - 10:55
can you provide the output of "df -h" on the server?
aureladmin
June 23, 2025 - 11:16
df -h
Filesystem                         Size  Used Avail Use% Mounted on
tmpfs                              391M  1.4M  390M   1% /run
/dev/mapper/ubuntu--vg-ubuntu--lv   98G   47G   47G  51% /
tmpfs                              2.0G  204K  2.0G   1% /dev/shm
tmpfs                              5.0M     0  5.0M   0% /run/lock
/dev/sda2                          1.5G  253M  1.2G  19% /boot
/dev/sda1                          1.1G  6.1M  1.1G   1% /boot/efi
tmpfs                              391M  4.0K  391M   1% /run/user/1000
aureladmin
June 23, 2025 - 3:54 PM
Test performed via the console: package present in the repository but with error 666 during "Build Upload"
Test performed via command line: package present in the repository but with error 666 during "wapt-get upload-package"
Upgrading the client to Windows 11 doesn't work via the generated package. Many errors occur
C:\WindowsUpgrade folder exists, continuing...
Free disk space: 93069709312 bytes
Force Upgrading Windows from version: 10.0.19045 to Windows version: 10.0.26100
Erreur lors de l'installation de ['epl-windows11-24h2']: erreurs dans les paquets [[PackageRequest(package='epl-windows11-24h2',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('epl-windows11-24h2','10.0.26100-115' architecture='x64',maturity='PROD',locale='fr',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 121, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4111, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2263, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5609, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4548, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4454, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 126, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2038, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n']]
  File "<string>", line 1662, in run
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 875, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 1484, in _run
Exception: Erreur lors de l'installation de ['epl-windows11-24h2']: erreurs dans les paquets [[PackageRequest(package='epl-windows11-24h2',architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('epl-windows11-24h2','10.0.26100-115' architecture='x64',maturity='PROD',locale='fr',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 121, in install\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4111, in run\n    return ensure_unicode(run(*arg, pidlist=self.pidlist,**args))\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2263, in run\n    raise CalledProcessErrorOutput(proc.returncode, cmd, \'\'.join(output))\nwaptutils.CalledProcessErrorOutput: Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5609, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4548, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4454, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\Windows\\TEMP\\waptk0hvzdpc\\setup.py", line 126, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 2038, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : Command \'"C:\\\\WindowsUpgrade\\\\setup.exe" /auto upgrade /quiet /eula accept /telemetry disable /showoobe none /copylogs "C:\\\\WindowsUpgradeLogs\\\\win11_upgrade_logs"  /compat ignorewarning /dynamicupdate disable\' returned non-zero exit status 3247440384.\nOutput:\n']]
    self._run()
One small additional point: If the version in the control file does not include the OS version at the beginning, it will not work, for example:
1) It works:
version           : 10.0.26100-115
The attempt to upgrade to W11 is launched via the package
2) This does not work:
version           : 0-116
The attempt to upgrade to W11 does not launch via the package, version lower than the OS version.
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
June 23, 2025 - 4:16 PM
Error 3247440384 indicates hardware incompatible with Windows 11.
Are there any logs in C:\WindowsUpgradeLogs\win11_upgrade_logs?
If not, you should check C:\Windows\Panther; there should be a setuperr.log file and probably an XML file starting with CompatData.
Regards,
July 8, 2025 - 09:49
Hello Aurélien,
were you able to resolve your problem?
Best regards,
Answer
