Files Corrupted, SHA not matching
Answer
MorganF
Registration: May 13, 2025 - 08:42
June 19, 2025 - 09:40
In the WAPT console, when I right-click on one of the packages in my private repository and choose "Edit in editor", I get the following error:
Error in package Execute_Exe_Forced (=1.0.6) in ....\Execute_Exe_Forced_1.0.6_windows_10.0.9884_10.0.0.1....
Files corrupted, SHA not matching for c:\waptdev\Execute_Exe_Forced_1.0.6_windows.....\WAPT
When I try to re-sign the package, I also get the following message:
Paquet;Version;Maturité;Statut;Message
Execute_Exe_Forced;1.0.6;PROD;ERROR;Error in package Execute_Exe_Forced (=1.0.6) in C:\Users\xxxxxx\AppData\Local\Temp\wapt-20250619-09262400000.tmp\stripped-wapt
Files corrupted, SHA not matching for C:\Users\xxxxxx\AppData\Local\Temp\wapt-20250619-09262400000.tmp\stripped-wapt\WAPT
Do you have any idea what might be causing this problem or a method to correct this SHA hash matching error?
Thanks in advance.
June 19, 2025 - 10:52
Hello Morgan,
what version of Wapt, OS version, etc.? See forum rules. :-)
Regards,
July 4, 2025 - 12:38
Hello Morgan,
since we don't have the Wapt version, regarding the returned log, is there a series of periods "." at the beginning or end of the filename? Or is it a substitution you made when posting on the forum? Normally, this filename should have simply been rejected, I think.
Regards,
Answer
