I used self-service to install packages on a client PC.
However, in self-service, I can see all the packages from my private repository except for uspn-windows11-requirements.
Could you please help me resolve this issue?
Kannan
[SOLVED] self service and windows11-requirements package
- WAPT Expert
Hello Kannan,
OS version, Wapt version, Wapt edition, etc. (see forum rules)
Has the uspn-windows11-requirements package been added to the self-service rule package [1]?
Regards,
[1] https://doc.wapt.fr/wapt-self-service.h ... prise-mode
Regards,
ravichandran
- Registration: Sep 4, 2024 - 11:36
Hello dcardon,
OS: Windows 11 24h2
WAPT Server version: 2.6.0.17293
WAPT Agent version: 2.6.0.17293
There is no self-service rule package.
Best regards,
kannan
OS: Windows 11 24h2
Best regards,
kannan
- WAPT Expert
Hello Kannan,
are you using the Discovery or Enterprise version (see WAPT Edition in my previous question)? This affects the possible self-service configuration options.
Regards,
Regards,
ravichandran
RE
WAPT enterprise version
CDL
Kannan
CDL
Kannan
- WAPT Expert
Hello Kannan
Can you run this command as administrator on the machine to simply see if the package is visible to the machine itself (without mentioning self-service)?
wapt-get search windows11-requirements --direct-
ravichandran
Hello simon,
command result: wapt-get search windows11-requirements --direct
C:\Windows\System32>wapt-get search windows11-requirements --direct
No result
Best regards,
kannan
No result
Best regards,
kannan
- WAPT Expert
The package isn't visible to the machine, so it has nothing to do with self-service.
I see in the package that it contains:
min_os_version: 10.0.18362
max_os_version: 10.0.19045.
Therefore, you need to be on at least Windows 10 1903
and at most Windows 10 22H2.
So the package won't install on Windows 11 (we'll change that).
Can you confirm that you are indeed trying to install it on Windows 11?
If you are indeed starting from a Windows 11 system, the package has been updated and you can test it again: https://wapt.tranquil.it/store/fr/detai ... _PROD.wapt
Have a good day,
Bertrand
Have a good day,
Bertrand
ravichandran
Thank you for the new package… it works…
Best regards,
Ravichandran
Best regards,
Ravichandran
