I have many machines experiencing errors due to the waptupgrade package. The version is 2.3.0.13516-29.
How can I resolve this issue?
Waptupgrade error
- WAPT Expert
Hello Laurent,
have the machines just been upgraded? Did the upgrade go through but the package failed? Is it the audit or the installation that failed? etc.
Lots of questions... Basically, we can start with the information requested in the forum rules: WAPT version, edition, server OS, client OS.
Then the context: is this an upgrade or normal operation? Which version are the problematic machines running?
Version 2.3 is end-of-life, so you should consider upgrading.
Best regards,
Best regards,
