We are having problems with the OS deployment; the installation is stuck on the waptagent.
We have the latest version:
WAPT Server version: 2.6.0.17392
WAPT Agent version: 2.6.0.17392
WAPT Setup version: 2.6.0.17392
WAPT Deploy version: 2.6.0.17392
DB status: OK
Have you ever had this problem?
Thank you for your feedback
OS Deployment Problem - WADS
- WAPT Expert
Good morning
You'll find our code here:
This would mean that the download of waptdeploy failed. Is it present and downloadable on the wapt server's web interface?
And in the correct version for the server?
if not WadsWget(MakeUrlPath([RepoUrl,'wapt','waptagent','waptdeploy.exe']),
MakePath([DefaultInstallDir,'waptdeploy.exe']), WaptData^.S['waptdeploy.exe'], 4000, 'Wapt Deploy Download') then
begin
UpdateWadsStatus('The waptdeploy.exe can not be found on the machine.', True, True);
Exit(Result);
end;
- WAPT Expert
Thanks for the feedback. Could you check the hash of waptdeploy on your WAPT server? (
https://srvwapt.mydomain.lan/wads/hash.json)
and the hash of waptagent:
(https://srvwapt.mydomain.lan/wapt/waptagent.exe)
Do you have a secondary repository?
I just checked the hash of https: //srvwapt.mydomain.lan/wapt/waptagent.exe retrieved from the webpage https://srvwapt.mydomain.lan/ in the file https://srvwapt.mydomain.lan/ .
There is no matching hash in the JSON file.
We are currently deploying secondary repositories (39) with rules, so it's quite possible the problem arose at that time. But where is the problem coming from?
- WAPT Expert
I don't understand, you don't have waptagent.exe in this file at all???Serv_info wrote: ↑August 7, 2025 - 9:40 AM I just checked the file https://srvwapt.mydomain.lan/wads/hash.json
- WAPT Expert
That's strange; it's as if the agent generation didn't work.
You can try going to "Tools" -> "Sign executables" in the console and try again.
