Greenshot version 1.2.10.6 has a significant CVE.
Version 1.3.296 was released on July 26th to fix this CVE.
I've noticed that the LUTI tests for this version are failing.
When do you expect to be able to release the package with version 1.3.296?
[RESOLVED] tis-greenshot CVE with CVSS at 7.8
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
- WAPT Expert
Hi Sébastien,
I just saw that the autobuild started but failed:
https://luti.tranquil.it/get_folder_res ... 93aW5kb3dz
The package as is would work for an upgrade but not for a fresh install. We'll look into why.
Greenshot has added a parameter for installations.
I just corrected the package for build 1.3.296.
The package will be available in pre-production for 5 days and then in production.
https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
Regards,
Regards,
