creating packages with exe
December 12, 2016 - 8:16 PM
This:
versionpaquet = control['version'].split('-',1)[0]
Allows you to retrieve the version from the control file
You are using this variable here:
install_exe_if_needed('pymecavideo-%s.exe' % versionpaquet ,'/VERYSILENT /SUPPRESSMSGBOXES /NORESTART /SP-','pymecavideo 6.3_is1',versionpaquet)
The uninstallkey command returns version 6.3 with:
 wapt-get list-registry pymecavideo
The version in the control file must therefore be 6.3-x
Otherwise, it will return an error of this type
Gaelds
Registration: Nov 22, 2015 - 08:37
December 13, 2016 - 8:06 AM
The version in the control file is "6.3.0-6"
