WADS-specific Ubuntu username
thomas789
Registration: May 31, 2021 - 3:44 p.m.
August 20, 2025 - 4:45 PM
We have configured our WADS to be able to deploy workstations running Ubuntu. The beginning of our basic cloud-config file is as follows:
#cloud-config
autoinstall:
  # version is an Autoinstall required field.
  version: 1
  identity:
    hostname: {{hostname}}
    username: monprenom
    password: "monmdp"
  locale: fr_FR.UTF-8
  keyboard:
    layout: fr
    variant: oss
  timezone: Europe/Paris
  packages:
    - ubuntu-desktop
    - gdm3
    - language-pack-fr
    - language-pack-gnome-fr
As can be seen from the {{hostname}} parameter, the script will use the hostname specified during the PXE boot of the machine. But is it possible to do the same for the username (instead of "myfirstname"), so that after deployment the machine has the name we specified during the PXE boot and we don't have to run usermod commands after deployment (especially for the user's session name, display name, and home)?.
Thanks in advance,
Sincerely.
blemoigne
Registration: July 17, 2020 - 11:29
August 21, 2025 - 4:20 PM
these won't be domain users.
thomas789
August 21, 2025 - 4:46 PM
No, there are no domain users.
Best regards.
blemoigne
August 22, 2025 - 4:55 PM
this could be handled by a package containing a dictionary {machine: user}. Depending on the machine, it would create the corresponding user.
Best regards,
Bertrand
thomas789
August 25, 2025 - 09:05
thank you for your feedback. However, is this package available in the WAPT store? If so, how is it used?
Regards.
blemoigne
August 25, 2025 - 12:11
There is no existing package, but it could look something like this:
    userdict = {'machine1': 'user1', 'machine2': 'user2'}
    user = userdict[host_info()['computer_name']]
And then perform all the actions of useradd/usermod with the retrieved user variable.
Best regards,
Bertrand
blemoigne
August 25, 2025 - 12:18
We could also use this package as a guide for encrypting the password:
https://wapt.tranquil.it/store/fr/detai ... _PROD.wapt
thomas789
August 26, 2025 - 2:37 PM
OK, but isn't it possible to have two prompts at the start of the WAPT PXE? One asking for the hostname (as is already the case) and one asking for the username, so that it can be used in the cloud init configuration.
Thank you in advance, best regards.
thomas789
September 18, 2025 - 4:32 PM
were you able to review my request?
September 19, 2025 - 9:29 PM
thomas789 wrote: August 26, 2025 - 2:37 PM Okay, but isn't it possible to have two prompts at the start of the WAPT PXE? One asking for the hostname (as is already the case) and one asking for the username, so that it can be used in the cloud init configuration.
Not currently.
We need to include "extra data" in WADs that could be used in templates. This extra data would be fed into the console. Currently, this isn't the case.
The most pragmatic solution in the meantime is to have the user join the domain and add the machine to the domain with an SSD (it works like Windows with local credential cache), so it seems like the most logical solution... Plus, it allows for automatic Kerberos authentication (coupled with Keycloak, it's perfect)
Answer
