WAPT Starter?
Answer
jcgensam
Registration: March 24, 2025 - 4:39 PM
September 19, 2025 - 09:58
does WAPT Starter still exist and is it still maintained? I can't find a direct installer on the WAPT website, apart from a WAPT package specifically for updating WAPT Starter (I can use it for the installation, of course, but it's less convenient than a dedicated installer, and the lack of an official installer is puzzling).
A related question: what telemetry data is sent to the Tranquil IT servers?
Thank you :-)
. Best regards,
JC
blemoigne
Registration: July 17, 2020 - 11:29
October 28, 2025 - 3:07 PM
It is located here: https://wapt.tranquil.it/wapt/releases/wapt-2.6/
For telemetry, the result from the API /api/v3/usage_statistics is sent:
C:\Users\administrator.BLEMOIGNE> wapt-get server-request /api/v3/usage_statistics --wapt-server-user=admin
Server: https://srvwapt.blemoigne.lan
Server CABundle: C:\Program Files (x86)\wapt\ssl\server\srvwapt.blemoigne.lan.crt
Server client certificate: C:\Program Files (x86)\wapt\private\1a8f64f4-333b-4c6a-bfef-dd8b609b73b5.crt
Server client key: C:\Program Files (x86)\wapt\private\1a8f64f4-333b-4c6a-bfef-dd8b609b73b5.pem
Basic realm="Login Required"
Waptserver Password: ************************
        "success": true,
        "msg": "Anomnymous usage statistics",
        "result": {
                "uuid": "6f325138-5d05-11e9-8d4b-0246ca169bbe",
                "platform": "Linux",
                "architecture":
                        "64bit",
                        "ELF"
                "version": "2.6.1",
                "date": "2025-10-28T14:02:28.152391",
                "edition": "enterprise",
                "git_hash": "2.6.1.17550",
                "hosts_count": 3,
                "oldest_query": "2025-10-28T12:36:39.999991",
                "newest_query": "2025-10-28T13:58:16.493737",
                "packages_count_max": null,
                "packages_count_avg": null,
                "packages_count_ok": null,
                "hosts_count_has_error": null,
                "hosts_count_need_upgrade": null
        "request_time": "0.004509449005126953"
Sending these statistics can be disabled in waptconsole.ini:
send_usage_report=0
Answer
