I'm looking for a solution to meet my needs.
The need:
To allow users to access an application catalog so they can select the applications they want on their workstations. Once selected, the application would install itself on the workstation.
Main constraint:
Multiple forests, without existing trust relationships.
Solutions considered:
Kace K1000,
SCCM
, WAPT.
My question:
I'd like to know if WAPT meets my needs, taking into account the major constraint of my project?
Thank you for your response.
Questions about WAPT features
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
- WAPT Expert
The feature you are looking for on wapt is the waptselfservice featureYannka wrote:Hello,
The need:
To allow users to access an application catalog so they can select the applications they want on their computers. Once selected, the application would install itself on the computer.
Users in the domain's waptselfservice group can install packages
Simply create a waptselfservice group on each forestYannka wrote:
Main constraint:
Multi-forests, with no existing trust relationships.
Kace K1000
SCCM
WAPT
My question:
I am trying to find out if WAPT meets my needs while taking into account the major constraint of my project?
Thank you for the reply.
Then, by creating a waptselfservice group on forests B, C, D and E, is that enough to connect to the server on forest A?
Let me reiterate: forests do not communicate with each other at all.
Let's imagine that I install the server on forest A.sfonteneau wrote:Simply create a waptselfservice group on each forestYannka wrote:
Main constraint:
- WAPT Expert
The remote sites don't communicate with each other?
It's still possible, but it all depends on the operating mode you want; Wapt is very modular.
Can you describe the constraints of your project in more detail?
The forests
The forests
