Fiji Package 2.17.0-0 installation problem
Answer
Aramis
Registration: July 16, 2024 - 11:48
October 15, 2025 - 2:41 PM
The package does not install correctly on a Windows 11 client.
1 - The shortcut does not point to the correct executable
2 - The installation by decompressing the zip file does not take place in the correct location, which prevents the program from updating later.
https://imagej.net/software/fiji/downlo ... -downloads
Caution: “Program Files” not recommended!
If you are installing ImageJ2 on Windows, we strongly recommend that you store your ImageJ2.app directory somewhere in your user space (e.g., C:\Users\[your name]\ImageJ2.app) rather than in C:\Program Files or other system-wide directory. If you move ImageJ2.app to such a directory, modern versions of Windows will deny ImageJ2 write permission to its own directory structure, preventing it from being able to update. See also imagej/imagej#72.
Server version: WAPT Enterprise 2.6.0.17392 on Linux Debian (Debian 6.1.140-1 (2025-05-22) x86_64 GNU/Linux)
Agent version: 2.6.0.17392
Client OS: Windows 11 (updated)
THANKS.
Commander.
blemoigne
Registration: July 17, 2020 - 11:29
October 16, 2025 - 09:11
Thank you for your feedback.
We will correct the shortcut target, but an application in a professional organization should not be installed in the user directory. We often prohibit the execution of binaries in the user directory. However, this will not be a problem because WAPT will update the application; there will be no automatic update.
Best regards,
Bertrand
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
October 16, 2025 - 10:00
Within the WAPT framework, auto-update is unnecessary because the packages are updated on our store, and simply importing a newer package from the console is enough to update the software.
However, we will contact the software publisher because user-level installations are not recommended; the best practice is to install for all users, as is the case with the current package.
Ingrid
Aramis
October 21, 2025 - 1:33 PM
Thank you for your feedback and for taking the corrections into account.
I agree with you regarding the security aspect of the deployment; unfortunately, this is a common practice among Java application developers.
Best regards,
Julien
Answer
