Disabling waptexit
Answer
silica
Registration: Nov 18, 2024 - 11:02
October 21, 2025 - 09:23
I need my users to install updates manually, so I need to disable automatic package installation when their PCs shut down.
How can I properly disable this feature?
Thank you in advance.
October 21, 2025 - 9:34 PM
Hello
https://www.wapt.fr/fr/doc/wapt-advance ... it-utility
You can use waptexit_disable_upgrade=0 in wapt-get.ini.
Waptexit will still start but will not launch any upgrades or installations.
However, during a shutdown, if an installation is already underway, it will restart to allow the installation time to finish what it started.
silica
October 23, 2025 - 3:47 PM
Thank you for your response.
Yes, I had seen that, but I can't find the option when I create a configuration package:
Am I required to deploy a manual modification to wapt-get.ini?
October 23, 2025 - 4:05 PM
Are you using an older version?
Screenshot 2025-10-23 160446.png (17.31 KB) Viewed 18195 times
silica
October 23, 2025 - 4:13 PM
Not the very latest one, I think; I'm on version 2.6.0.16552
Answer
