Build Wapt Agent
Answer
rdegaet
Registration: Nov 7, 2025 - 1:51 p.m.
November 7, 2025 - 2:01 PM
Hello, I'm new to WAPT. I've installed the latest version of the server on Linux and the management console on Windows 11, both with the Discovery edition. My problem now is that when I try to create an agent build, I can't select 'use Kerberos' because it's not an option. This means I have to change the setting on each workstation to 1. What could be the problem? The waptsetup.iss file doesn't exist in the C:\Program Files (x86)\wapt\waptsetup directory; is that normal? Thanks in advance to anyone who can help.
November 13, 2025 - 4:18 PM
On the server, in the directory
C:\wapt\waptserver\repository\wapt\conf.d
or on Linux
/var/www/wapt/conf.d,
there is a JSON file that begins with default_xxx.json
. You can delete or edit it.
It contains the values ​​that will be integrated into the custom agent
in %localappdata%/waptconsole/waptconsole.ini.
Also, check that it does not contain user_kerberos=1
and recreate the custom agent.
Answer
