wapt-get clean isn't cleaning.
Is it safe to manually empty the wapt\cache folder?
[SOLVED] wapt-get clean does not clean
- Attachments
- Screenshot 2025-11-13 at 09:33:34.png (49.17 KB) Viewed 11895 times
WAPT Enterprise Server: 2.6.0.17343 / Server OS: Debian bookworm /
Administration/package creation machine OS: macOS 15
- WAPT Expert
indeed, this scenario wasn't anticipated.
The cache directory was moved to:
C:\Program Files (x86)\wapt\private\cache.
Historically, it was located in:
C:\Program Files (x86)\wapt\cache.
However, a clean installation should have been performed during the upgrade.
In your case, you can delete the .wapt files from the old folder.
