Two Wapt agents
Answer
filou07
Registration: December 6, 2018 - 3:33 PM
November 12, 2025 - 08:11
Hello everyone,
what configuration would be needed for a computer to have two WAPT agents communicating with two different servers?
Thank you in advance for your answers!
vcardon
November 12, 2025 - 7:51 PM
Hello, would you like to explain your use case?
filou07
November 14, 2025 - 08:04
Yes, in my company I have installed a WAPT server accessible from several branches. For two reasons, I want to create a WAPT server in a specific branch:
- it would serve as an independent "laboratory" for creating "dev" packages without polluting the "production" server
- and I also want to create packages that would only be visible from this branch.
There you have it, I hope I have explained my use case.
vcardon
November 14, 2025 - 11:24 PM
Hello, you'll find a better solution using the maturity system (maturities) in the control file.
I suggest you search the documentation and the forum; it seems to correspond to what you want to do.
filou07
November 17, 2025 - 08:23
too bad for me.
Thanks anyway.
Answer
