WAPT Version: 2.6.1.17567
Server OS: Debian 12
Administration Machine OS: Windows Server 2022
Target OS: macOS 26.0 and 14.5
since installing the new version, in the administration console some of our Macs are showing up with a name in the format "1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa" while others are not (same OS).
Each Mac has a hostname in the format "macXX.local".
Have you encountered this issue before?
Thank you
macOS: problem reported, machine name
- WAPT Expert
is the Mac on the domain?
Does a /etc/krb5.keytab file exist?
- WAPT Expert
On a Mac, it would be interesting to do a:
wapt-get shell
>>> from setuphelpers import *
>>> get_hostname_and_domain()
- WAPT Expert
I think you'll end up here in any case:
Who performs an IP-to-name resolution to obtain a fully qualified domain name (FQDN)?
We would need to change that in wapt but it's more of a headache than it seems.
In your case, logically you should retrieve only the hostname, but without the domain.
import socket
socket.getfqdn()
I placed the orders but received an error message:sfonteneau wrote: ↑Nov 18, 2025 - 3:28 PM On a Mac, it would be interesting to do a:
wapt-get shell >>> from setuphelpers import * >>> get_hostname_and_domain()
File "<console> ", line 1, in<module>
NameError: name 'get_hostname_and_domain' is not defined
So I would need to remove ".local" from the hostname?sfonteneau wrote: ↑Nov 18, 2025 - 3:31 PM In your case, logically you should retrieve only the hostname, but without the domain
- WAPT Expert
Just try doing this:
`import socket
socket.getfqdn()
` to verify the theory
`import socket
socket.getfqdn()
- WAPT Expert
So that's right,
it's the socket library integrated into Python that's communicating, see:
https://docs.python.org/3/library/socke ... et.getfqdn.
Here it's the reverse IP address resolution that's working...
try putting a "." in the hostname to see if that works, but I doubt it will.
