[SOLVED] Packages for Logi Options+ (Windows / MacOS)
bastien30
Registration: March 8, 2024 - 3:21 PM
November 20, 2025 - 12:26
I made a package for the Logi Options+ software under Windows and MacOS, with update_package() functional.
Windows
setup.py:
from setupdevhelpers import *
installer = r'logioptionsplus_%s.exe'
    appver = control.version.split('-',1)[0]
    install_exe_if_needed(installer % appver,
        silentflags = '/quiet /analytics no /device-recommendation no /update no',
        name = 'Logi Options+',
        min_version = get_version_from_binary(installer % appver, property_name='ProductVersion')
    remove_desktop_shortcut(r'Logi Options+')
def update_package():
    appname = control.name
    url_dl = control.sources
    installer_dl = r'logioptionsplus_latest.exe'
    # Download installer to check its version
    wget(url_dl, installer_dl)
    installer_dl_version = get_version_from_binary(installer_dl)
    print(r'Latest %s version : %s' % (appname, installer_dl_version))
    if Version(installer_dl_version) > Version(appver):
        os.rename(installer_dl, installer % installer_dl_version)
        control.version = '%s-%s'%(installer_dl_version, control.version.split('-')[-1])
        print('Changing version to: %s in WAPT\\control' % control.version)
        remove_outdated_binaries(installer_dl_version)
        print("Already up to date")
control:
package           : xxx-logi_options_plus
version           : 1.97.791262-3
architecture      : x64
section           : base
priority          : optional
categories        : Utilities
maintainer        : XXXX
description       : Enhance your Logitech devices with Logi Options Plus software. Customize settings, create shortcuts, and increase productivity.
depends           : xxx-vcredist2015-2022
conflicts         :
maturity          : PROD
locale            : all
target_os         : windows
min_wapt_version  :
sources           : https://download01.logi.com/web/ftp/pub/techsupport/optionsplus/logioptionsplus_installer.exe
installed_size    :
impacted_process  : logioptionsplus,logioptionsplus_agent,logioptionsplus_appbroker,logioptionsplus_updater,LogiSyncStub
description_fr    : Améliorez vos appareils Logitech grâce au logiciel Logi Options Plus. Personnalisez les paramètres, créez des raccourcis et augmentez votre productivité.
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Logitech, Inc.
keywords          :
licence           : Proprietary
homepage          : https://www.logitech.com/software/logi-options-plus
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://support.logi.com/hc/fr/articles/1500005516462-Logi-Options-Release-Notes
min_os_version    : 10
max_os_version    :
macOS
setup.py:
import plistlib
installer_name = r'logioptionsplus_installer'
    installer_zip = r'%s_%s.zip' % (installer_name, appver)
    installer = r'./%s_%s/%s.app/Contents/MacOS/%s' % (installer_name, appver, installer_name, installer_name)
    soft = installed_softwares(r'logioptionsplus')
    if soft:
        if soft[0]["version"] >= appver:
            if not WAPT.options.force:
                print(r'%s is already installed with version %s' % (appname, soft[0]["version"]))
                return(0)
    unzip(installer_zip, r'%s_%s' % (installer_name, appver))
    run(r'%s --quiet --analytics no --device-recommendation no --update no' % installer)
    # Uninstall and clean leftovers
    run(r'sudo /Library/Application\ Support/Logitech.localized/LogiOptionsPlus/logioptionsplus_agent.app/Contents/Frameworks/logioptionsplus_updater.app/Contents/MacOS/logioptionsplus_updater --full --uninstall --quiet')
    uninstall_pkg(r'com.logi.installer.pluginservice.media.package')
    uninstall_pkg(r'com.logi.installer.pluginservice.package')
    if isdir(r'/Library/Application\ Support/Logi/'):
        remove_tree(r'/Library/Application\ Support/Logi/')
    installer_dl = r'%s.zip' % installer_name
    plist_file_name = r'Info.plist'
    # Download installer to check it's version
    # Check version from plist file
    if isfile(plist_file_name):
        remove_file(plist_file_name)
    unzip_with_7zip(installer_dl, target=basedir, filenames=[r'%s.app/Contents/Info.plist' % installer_name], extract_with_full_paths=False, recursive=False)
    plist_file = get_plist_obj(plist_file_name)
    installer_dl_version = plist_file[r'CFBundleVersion']
        old_zip_name = r'%s-%s.zip' % (installer_name, appver)
        if isfile(old_zip_name):
            remove_file(old_zip_name)
        os.rename(installer_dl, r'%s_%s.zip' % (installer_name, installer_dl_version))
def get_plist_obj(plist_file):
    """ Returns a plist obj when given the path to a plist file. """
    with open(plist_file, 'rb') as fp :
        plist_obj = plistlib.load(fp)
    return plist_obj
control:
version           : 1.97.791262-8
architecture      : all
section           : base
priority          : optional
maintainer        : XXXX
depends           :
conflicts         :
maturity          : PROD
locale            : all
target_os         : darwin
min_wapt_version  :
sources           : https://download01.logi.com/web/ftp/pub/techsupport/optionsplus/logioptionsplus_installer.zip
installed_size    :
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
keywords          :
valid_from        :
valid_until       :
forced_install_on :
min_os_version    : 13
max_os_version    :
gadam
Registration: Oct 30, 2025 - 2:46 p.m.
November 21, 2025 - 4:30 PM
Hello Bastien,
The Logi Options+ package has been created for Windows and will be available on the store in the coming days.
We are still working on the Mac version.
Regards,
Gwenaël
