Slow access to the server homepage/timeout during updates
Answer
Vincent38
Registration: May 22, 2023 - 12:13
November 23, 2025 - 4:25 PM
I've been having a problem for a while now that I can't seem to solve.
When I try to access the server's homepage via HTTP, there's no problem; it's instantaneous. However, with HTTPS, it takes at least ten seconds before I even get to the login prompt.
There's no problem launching the console (which points to HTTPS), but I occasionally get timeouts on the WUA side on certain clients (not always the same ones), with the error message "THttpClientSocket.OpenBind(wapt1.xxx.xxx.com:443): Is a server available on this address:port? [remoteip=] [#3 Not Found]".
There's nothing obvious in the Nginx and Wapt logs. Any idea what could be happening?
I have the impression that it started after the update from version 2.5 to 2.6.
Thank you
WAPT 2.6.1.17576
Debian 12 server
, creation machine Win 11 24h2
November 24, 2025 - 09:28
If the problem is related to https, I suppose it's due to missing flags on the CPU side.
You can send back the order result!
cat /proc/cpuinfo |grep flags
Vincent38
November 24, 2025 - 11:55 AM
There :
root@WAPT1:~# cat /proc/cpuinfo |grep flags
flags           : fpu de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx lm constant_tsc nopl xtopology cpuid tsc_known_freq pni ssse3 cx16 sse4_1 sse4_2 x2apic popcnt aes hypervisor lahf_lm cpuid_fault pti
This is a Proxmox VM, CPU type x86-64-V2-AES, machine type i440fx
Commander
November 24, 2025 - 12:31
Vincent38 wrote: Nov 24, 2025 - 11:55 AM It's a Proxmox VM, CPU type x86-64-V2-AES, machine type i440fx
It would be interesting to see if the AES is emulated (which consumes power).
You can switch to host-type CPU to see if
always refers to aes
Vincent38
November 24, 2025 - 12:54
Indeed, the AES has disappeared, but that hasn't solved the problem.
flags           : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl xtopology cpuid tsc_known_freq pni pclmulqdq vmx ssse3 fma cx16 pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm rdseed adx smap xsaveopt arat umip md_clear flush_l1d arch_capabilities
vmx flags       : vnmi preemption_timer posted_intr invvpid ept_x_only ept_ad ept_1gb flexpriority apicv tsc_offset vtpr mtf vapic ept vpid unrestricted_guest vapic_reg vid shadow_vmcs pml
root@WAPT1:~#
This problem did not exist (I think) on version 2.5, but I don't remember changing anything on the VM/OS side during the migration to 2.6.
Perhaps there was a problem during the migration? Especially since I seem to remember seeing something strange with the certificate (a self-signed one) a few days ago when I was looking for the cause, but unfortunately I can't remember how or which command I used to see that strange thing. :D
I was thinking of generating a new certificate for testing purposes, but I couldn't find the procedure to follow.
Vincent38
November 24, 2025 - 1:05 PM
Luckily, I remembered doing a Google search for this error, so I was able to find it in my history. The certificate is valid until 2033, but it says "CRL validation error on certificate."
I must have made a mistake during the migration; I've always had trouble understanding these certificate issues. :D
November 24, 2025 - 2:02 PM
Vincent38 wrote: Nov 24, 2025 - 12:54 Indeed, AES has disappeared, but that hasn't solved the problem.
aes is indeed present ;)
So that's not it.
One of the big changes that occurred between 2.5 and 2.6 is client certificate authentication.
I don't really see what could slow things down.
Vincent38
November 24, 2025 - 5:34 PM
Okay, well, I won't bother with it any longer. Since Debian 13 is out, I'll back up the server and start with a clean install, hoping that will resolve the issue. :D
Two questions:
I'm starting to run out of space because of old Windows updates still on the server. If I don't transfer the /var/www/waptwua/ folder during the backup, will it clean things up? Will Wapt re-download what it needs?
The restore procedure mentions doing a standard installation, but is it necessary to run postconf.sh?
Especially since it needs to be restarted after importing the old data?
Vincent38
January 21, 2026 - 11:44
Okay, I haven't done a clean reinstall yet, but strangely enough, after updating the WAPT server yesterday, the problem disappeared :D ; no more slowness or timeouts.
We can close this topic!
Answer
