PyScripter Problem
Answer
ssalle
Registration: Nov. 24, 2025 - 11:06
November 24, 2025 - 11:13
I installed the tis-waptdev tools and Pyscripter version 3.6.4.0 x86.
The WAPT agent on the same machine is version 2.6.1.17472.
When I try to edit a package, I get the error "Pyscripter could not find a usable Python installation at the specified path".
If I try to define the path by selecting c:\Program Files (x86)\wapt, I get the same message.
Have you ever encountered this problem?
Thank you,
Stéphane
November 24, 2025 - 11:20
PyScripter3 has been updated to version 3.7.0 (to support 3.10)
https://wapt.tranquil.it/store/fr/tis-pyscripter3
ssalle
November 24, 2025 - 12:03
this version solved my problem.
Thank you!
Answer
