[SOLVED] Importing large packages onto the WAPT server
erems
Registration: Apr 25, 2023 - 3:52 p.m.
November 27, 2025 - 4:48 PM
I often have trouble importing large WAPT packages (for example, the 7GB Windows11-upgrade) into our private repository. I frequently get error messages.
I was wondering if there wasn't a better way to import these packages, perhaps by downloading the package from the store and then transferring it directly to our server?
In any case, if you have any tips, I'd appreciate it.
Thanks.
PS: Sometimes, even after the error message, the package appears in the repository. Generally, I delete it just to be safe. When this happens, is there a way to verify that the package is indeed legitimate (without having to install it)?
blemoigne
Registration: July 17, 2020 - 11:29
November 28, 2025 - 10:21
Here is the documentation: https://www.wapt.fr/fr/doc/wapt-faq-pac ... repository
Have a good day,
Bertrand
erems
December 1, 2025 - 5:09 PM
Yes, thank you, we'll try that.
