Problem accessing Self-Service via FortiClient VPN
Answer
PA DEQUIDT
Registration: Oct 27, 2025 - 4:18 p.m.
November 19, 2025 - 08:37
We have the following problem with users of a Forticlient VPN.
Accessing their Self-Service system when connected via VPN displays no results, even though the machine is reachable via the console.
However, if the selservice is reconnected, access is restored about half the time.
Here is a list of all the actions we have already taken:
  • Traffic audit = No traffic is blocked, either to the primary or secondary repository on ports 80 and 443.
    Agent uninstalled and then reinstalled.
    WAPT services stopped and then restarted.
If you have any ideas for finding a solution, they would be more than welcome. :D
November 19, 2025 - 09:45
Try doing this in a regular command prompt:
And do this while the VPN is running:
C:\Windows\System32>wapt-get shell
>>> from waptservice.service import get_allowed_domain_usergroups
>>> get_allowed_domain_usergroups('username',['nomedugroupe'])
['nomedugroupe']
['nomedugroupe']
['nomedugroupe']
Rerun get_allowed_domain_usergroups several times to see
You can also try:
>>> import pyldap
>>> print(pyldap.cldap_get_domain_info()['host_name'])
To see if it's still returning the correct DC
PA DEQUIDT
November 21, 2025 - 2:46 PM
Sorry for the late reply. I rely on third parties, but my VPN is working perfectly. :)
Here's the return of orders:
>>> import pyldap
  File "<console>", line 1, in <module>
TypeError: 'NoneType' object is not subscriptable
FRRNS-SAD01.sii.fr
FRRNS-SAD02.sii.fr
FRRNS-SAD01.sii.fr
FRRNS-SAD02.sii.fr
In view of the order response, I better understand the random aspect, namely that about half the time the Selfservice responds.
Do you think it's a flow problem or something else entirely?
Best regards,
Pierre-Alexis DEQUIDT
November 21, 2025 - 3:11 PM
Thanks for the feedback
Could you try increasing the timeout?
import pyldap
print(pyldap.cldap_get_domain_info(timeout_ms=3000)['host_name'])
PA DEQUIDT
November 24, 2025 - 09:33
The increased timeout results in an error half the time, corresponding to the accessibility of the self-service area.
import pyldap
Could the WAPT logs on the client machine tell us more?
November 24, 2025 - 11:35
This should be tried several times to see:
import pyldap
pyldap.cldap_get_ldap_controller('sii.fr')
PA DEQUIDT
December 2, 2025 - 2:47 PM
Following the commands provided, we were able to deduce that the error stemmed from recurring requests to two of our old domain controllers.
Once the VMs were decommissioned, the service reached 100% availability again.
Thank you very much for your help.
Answer
