I have a question I can't seem to find the answer to.
I'm connecting to a corporate console on a remote primary repository (WAN) that uses HTTPS, which I'll call Principal01.fr.
Principal01.fr has the IP address 192.1.1.3.
A Group Policy Object (GPO) on a Windows domain deployed the WAPT agent to the machines with the following settings in wapt-get.ini:
repo_url=https://Principal01.fr/wapt
wapt_server=https:/Principal01.fr.
I then set up a secondary repository (LAN) using HTTP, which I'll call Secondary02.fr, and it seems to be working correctly: it synchronizes properly with Principal01.fr.
Secondary02.fr has the IP address 192.168.1.3.
I added a rule based on the clients' IP addresses:
If the client belongs to the 192.168.1.00/24 network (I put "00" in the subnet mask because that's what the documentation I'm supposed to follow indicated), then the repository used should be:
http://Secondaire02.fr/wapt.
I checked WAPT, WUA, WADS, and disabled fallback.
However, on my console (on Principal01.fr), when I go to the Inventory section and select a client from the 192.168.1.00/24 range, in the Repositories tab, I only see the primary repository, and not the secondary one.
Package downloads from the clients seem very slow for a LAN deployment, and I suspect the clients are connecting directly to Principal01.fr.
My questions are therefore as follows:
Is it normal that, in the machine inventory, the displayed repository is Principal01.fr and not Secondaire02.fr (is this simply a reflection of the wapt-get.ini file)?
How can I verify that my clients are correctly retrieving packages from the secondary (LAN) repository?
[RESOLVED] Inventory only displays the main repository: normal behavior?
- WAPT Expert
Good morning
In terms of value, this is indeed not allowed; the Python code will not accept:
KO
OK
Can you provide the link to the documentation that specifies to enter 00?cedric_974 wrote: ↑Dec 2, 2025 - 12:21 If the client belongs to the 192.168.1.00/24 network (I put “00” in the subnet mask because that's what the documentation I'm supposed to follow indicated),
KO
>>> ipaddress.ip_network("192.168.1.00/24")
File "<interactive input>", line 1, in <module>
File "ipaddress.py", line 83, in ip_network
ValueError: '192.168.1.00/24' does not appear to be an IPv4 or IPv6 network
>>> ipaddress.ip_network("192.168.1.0/24")
IPv4Network('192.168.1.0/24')
cedric_974
- Registration: Nov 13, 2025 - 05:42
I've corrected the rule and will implement further updates to assess the network impact.
Regarding the documentation, it's an internal procedure, not official documentation.
Thank you for your help.
cedric_974
Hi again,
I can confirm that it's working and the secondary repository now appears in the machine's inventory.
